Engine Code Help?
Basically I want to rebuild a XUD engine to a reliable 180/190 bhp I know some of the basics I need TD04, 11m bosch, FMIC etc..
I have been trolling the net looking for information on engine codes I found something on Wiki but not sure on how true it is:
XUD9 65 PS (64 hp/47 kW) Diesel
XUD9 A 71 PS (70 hp/52 kW) Diesel
XUD9 TE/L 92 PS (90 hp/67 kW) Diesel turbo with intercooler
XUD9 SD 63 PS (62 hp/46 kW) Diesel turbo catalyst
XUD9 SD 75 PS (74 hp/55 kW) Diesel turbo catalyst
XUD9 TE/Y 90 PS (88 hp/66 kW) Diesel turbo with intercooler catalyst
XUD9/Z
I am trying to find a good starting point whats the difference in these engines etc... whats the best? I have read a few places that HDI rods are better but hopefully looking at forged if some one gets a group buy going
Thanks in advance guys
The hdi rods are stronger than all the XUD ones, get them swapped out as a starting point. There's plenty of info on this on other threads but make sure you get your pump/boost setup properly aswell, I found this had quite an effect on the reliability of the block.
Yeah I agree with dave
(08-12-2013, 04:09 PM)Dave Wrote: The hdi rods are stronger than all the XUD ones, get them swapped out as a starting point. There's plenty of info on this on other threads but make sure you get your pump/boost setup properly aswell, I found this had quite an effect on the reliability of the block.
Yeah cheers for that mate do you know if darren is still building pumps?
Also anyone got any information on if the block, head, injectors is different etc.. as there is a change in power..
Bump Big Grin
  Peugeot 306 7a.c.s Hatchback 2001 1.9 WJZ engine code rotjuh77 0 2,518 29-07-2019, 10:55 AM
Last Post: rotjuh77
Star Xud engine code/ internal parts needed mrmoates 4 4,869 29-09-2017, 09:08 AM
Last Post: welshpug
  What engine code? Nathan1305 4 3,320 27-07-2014, 07:23 PM
Last Post: Nathan1305
