Rattle - My Crank Pulley is Green!
My HDi has developed a rattle lately. Rattle makes an appearance just above idle, and sounds much like a buggered tappet. At higher revs, it sounds more harsh. I figured it was probably the crank pulley, as when you first fire it up the lights flicker with a small rev, so had a look today. My crank pulley is green!
[Image: 3tc0.jpg]
Problem is, I listened for the rattle and it doesn't sound like it is coming from the pulley, more from the camshaft sprocket.
Looks like a pulley is on the cards anyway, plus I was always planning a cambelt/tensioner overhaul. But anyone got other ideas?
What pulley is it I need for the 307 conversion? EuroCarParts list loads!
Is that coolant on the pulley? Waterpump failing?
i would think its the die out the aircon system that has turned the pulley green
What i would do 1st is to take the aux belt of and start the engine for a few seconds
and see if its still making the noise
As it might be the A/C pump as i just bought a car for spares at that was making a noise like you describing and it turned out to be the A/C pump
Aircon die is green as said. I cut mine over a white concrete drive. Still not come out I need to get some good cleaner that reminds me
TD04 11mm Sedan, now 2.1 vnt
Provence Dturbo Dead
Blaze 1.6 Dead
There is a cambelt tensioner just below the camshaft sproclet, maybe worth a check.
Look for my recent post about crank pulley, there are only two to choose from at ecp the correct diameter. A Cheap one and a supposed oe quality one.
[Image: wallye-gtd.JPG?raw=1]
HDi Owner for 200k/9 years
Good point about the AC dye, it doesn't look as though there's any on the AC pulley though. Confused
(07-12-2013, 08:28 AM)HDIkyle Wrote: Aircon die is green as said. I cut mine over a white concrete drive. Still not come out I need to get some good cleaner that reminds me
Good luck getting that out..... I got some dribbled down my jeans in July.....its still there after numerous washes! Dodgy
  Crank pulley compatibility Dreijers 0 2,291 01-06-2017, 01:22 PM
Last Post: Dreijers
  Middle box delete and crank pulley allye 27 15,794 29-10-2016, 06:41 AM
Last Post: allye
  Jingle Jangle rattle noise? tigerstyle 9 6,177 06-06-2016, 09:07 AM
Last Post: Toms306
