Oil cooler takeoff on rad
Got a new rad phase 1 off a s16 but it don't have the oil cooler outlet the one that points towards the passenger side on the back. Is there anyway around this? Maybe pipe it into the top pipe instead?
TD04 11mm Sedan, now 2.1 vnt
Provence Dturbo Dead
Blaze 1.6 Dead
sounds like you need a GTI6 rad
Ye so are all s16 fads different ? Might just bond the pipe on
Blaze 1.6 Dead
think the 6 is the only one with the oil cooler take off in the centre left of the rad
not sure others even have the oil cooler
Dturbo do all ones iv had anyway come like that standard. Might be able to do something tho. Take it off other rad maybe
Blaze 1.6 Dead
phase 1 DTurbo rad is similar.
I've got a ph1 nissens rad for a dt
The ph1 DT rad has it.
Just T it into the lower rad hose.
The engine simply uses the oil cooler as an "extra" feed from "rad" to "water pump"
Ok cheers so its not a return
Blaze 1.6 Dead
  Rev counter sender takeoff on Xud11 2.1 HDIkyle 4 3,573 28-11-2016, 10:00 PM
Last Post: bashbarnard
