03-12-2013, 01:36 PM
Bulb works
Wires all seem to be intact and seem to have good enough connection
What else could it be ?
Drivers side full beam won't work??
Bulb works
Wires all seem to be intact and seem to have good enough connection What else could it be ?
03-12-2013, 01:46 PM
how do you know bulb works? tried it in other side? .
03-12-2013, 02:42 PM
Put it to a battery charger..
03-12-2013, 03:02 PM
check the fuse in the fusebox under the bonnet
Fuse?
03-12-2013, 03:55 PM
But would a fuse not cause both not to work ?
03-12-2013, 04:54 PM
fonts have seperate fuses for left/right, dip and main beam
03-12-2013, 05:09 PM
Happy days must check them when I get out of work thanks
03-12-2013, 05:46 PM
Fuse was blown sorted now thanks
| Fuel guage stuck on full, but returns to zero with engine off. Will red light work? | Charlie0 | 6 | 5,073 |
11-09-2018, 10:11 PM Last Post: Charlie0 |
| passenger headlight not going full beam?? | RichyMRX | 7 | 3,820 |
30-09-2014, 09:18 AM Last Post: Eeyore |
| Finally set about the drivers side door loom! | wacker315 | 3 | 2,918 |
17-09-2014, 04:35 PM Last Post: cully |
