Finally set about the drivers side door loom!
Well i have finally set about the drivers side door loom between the door and pillar and to my amazement all the wires look spot on so i dont know what to check next? I am having trouble with my electric windows and neither of them work. They have just gradually just got worse to the point now where they dont work at all and its like to power at all is getting to the motors in the doors as i cant hear anything when pressing both the drivers side switch and also the passenger side. My central locking also never locked and unlocked straight away which defo pointed to a dodgy door loom but as i said earlier all the wires look good. Any suggestions please?
Even if they look OK on the outside, the wires could still be broken internally so there's no / intermittent connection.
ok will try and pull a plug from the scrappy then and go that way. Is the door loom the same for all the 306 phase 3s? or is 5 door different to 3 door etc?thanks
you need to count the wires used at the plug as lower base models didnt get the full loom plug of all the wires
  off side Electric window and door not working bluebenz1 1 3,304 01-05-2018, 10:07 AM
Last Post: pug306driver
Wink Door Loom Swapped - Central Locking Fault! partybish 8 6,812 29-09-2017, 08:58 PM
Last Post: paulgtt
  drivers door loom wires pug306driver 3 3,450 27-11-2016, 06:29 PM
Last Post: BiG K
