intercooler piping kits?
Can anyone point me in the right direction towards a decent piping kit that will have nearly all the connectors needed etc. for front mounting my car?
Any links to a previous buy would be awesome , cheers
Most of the universal kits will be fine, the 'medium size' toyosports cooler is perfect for a single pass FMIC.. you need PLENTY of 90 degree bends, silicon and metal. DO NOT get anything bigger than a 2.25" kit because it will just make life more difficult for yourself fitting it, for little to no gain at all.
(27-11-2013, 10:51 AM)Midnightclub Wrote: Most of the universal kits will be fine, the 'medium size' toyosports cooler is perfect for a single pass FMIC.. you need PLENTY of 90 degree bends, silicon and metal. DO NOT get anything bigger than a 2.25" kit because it will just make life more difficult for yourself fitting it, for little to no gain at all.
sweet , ill have a look into it more tonight. so definitely not to go for 2.5'' then? i though the 406/xantia inlets were 2.5''?
*thought
this the one you're referring to then? - http://www.ebay.co.uk/itm/FMIC-FFRONT-MO...4880777%26
Don't go near 2.5".
2"-2.25" is ideal.
Xantia inlet is 2.25".
(27-11-2013, 11:06 AM)silverzx Wrote: Don't go near 2.5".
2"-2.25" is ideal.
ahh no worries , i should of just stopped being lazy and measured it.
all is good , just need some pennies now, cheers Smile
Yeah that cooler you linked is the exact same one i've got, a lot thicker than it looks in the pics but does the job very well and fits find behind the bumper
2"-2.25" is ideal.
Meh, it's the sort of thing once you've measured it ten times it kind of gets hard to forget..!
If you have a ph1 radiator I'd be tempted to go 2" and squeeze it around either side.
Otherwise if its 2.25" loop it back and take both around passenger side of radiator.
I might have the couple OEM pipes that came off the xantia...
2"-2.25" is ideal.
Mines 2.5" Tongue
You cut 2 holes in the chassis though.. that's cheating Tongue
^^ lol
(27-11-2013, 01:12 PM)Midnightclub Wrote: You cut 2 holes in the chassis though.. that's cheating Tongue
Fair point Smile
i have the majority of a 3" kit.
3" is for bad-men e.g. Padge. Tongue
  fmic piping philpemberton94 7 4,686 04-11-2014, 02:32 PM
Last Post: silverzx
  Where do you get your XUD9 cambelt/timing kits? silverzx 8 4,466 09-10-2013, 08:12 PM
Last Post: Chris_90
  Turbo inlet and piping re-route questions (Pics and new Q's) ginge191 45 25,004 23-01-2012, 09:47 AM
Last Post: silverzx
