Clutch bite point
just bought a 02 Hdi estate and the clutch is biting about 10mm off the floor, not sure if the clutch is new or on its way out, or if i should just change the cable? its the first Hdi iv owned
A low bite is better than a high one. Smile
Just had my clutch changed, Mine was literally on the floor before it was biting. Not sure if just changing the cable will help .. Are they not auto adjusting ?
On the 306 waiting list.
just gave it a test, it would rather stall than slip, its like the self adjuster has not reset after a new clutch, is it possible to manually push the ratchet back in?
I heard that stamping on the pedal can sometimes sort the adjuster :/ i wouldnt try it til its been confirmed though haha
Also heard that if you spray a bit of wd40 onto the cable it will work it's way up to the ratchet it helps with the problem. Again not confirmed but something to look into.
should fit a new cable with a new clutch Smile
a few hard stamps on the pedal might help but I doubt it will in this instance!
Team Orange Engine Bay
Few hard stamps will make it tighter! If you push it down then let go of the pedal so it springs back a few times, that'll loosen up the cable and then it'll auto adjust once you start driving
Toms306 Wrote:A low bite is better than a high one. Smile
Thats good news mine comes up 1/4 so there must be loads left. Big Grin Popcorn
  Clutch biting point shervo 2 2,811 19-03-2015, 08:34 AM
Last Post: shervo
Tongue Crank gear setting point Mr_Nuclear 9 7,493 29-12-2014, 08:30 AM
Last Post: Mr_Nuclear
