Turbo swap Newbie.
Hiya,
It appears i may have to swap the turbo on the 306. Never done one before. Total newbie to the whole diesel thing.
Is there anything specific i should be wary of in this process? Any hints and tips would be very much appreciated.
Put a jack under the sump
Take the drivers side engine mount off
Lower the jack this will tilt the engine forward giving access to the inlet manifold and turbo.
Its not too bad
Cheers james
[Image: av5ym8.jpg]
You could always watch Darrens video on YouTube a couple of times to get a jist for it.
Rubber o ring for the fuel line. We're u based?
Venetian XUD ph2 heaven
Ph3 perv cab heaven
Black ph1 XUD died
Moonstone hdi stage 2
Cheers James,
Silverzx, do you happen to have a link you can post to the vid? that would be ace!
Karl, I'm in South Wales.
Thanks for the tips. x
The exhaust studs are always the biggest ball ache I find.
http://www.darrenjlobb.co.uk/home/xud-turbo-change
Feel free to give me/Darren reputation.
When you lower the engine grab the inlet and pull engine forward to get more room!
Be liberal with wd40 on the exhaust/inlet bolts. I've not had an issue myself but read a few times where people have snapped and/or rounded them
Also disconnect exhaust from the top of the downpipe first as when the engine is pulled forward it will strain the joint making them harder to undo - Again plenty of wd40.
What turbo is going back on? If its off, it may be a good time for an upgrade......
HDi Cabby Project Click
Can't afford to upgrade at the minute. So it'll just be a standard. It's just done the classic "running on it's own oil" thing where it revs high.. that's gotta be the turbo oil seals hasn't it?
Yea, more than likely. May be worth just checking the breather pipes first but I think your probably right.
Ceri where abouts in south wales? Im in np44 if u need hand/me to do it
If it's been running on its own oil make sure you clean the oil out of the intercooler and inlet
Team Doesn't own a 306
It was terrifying really!! like a thing possessed!
(22-11-2013, 10:34 PM)Seb_Ryan Wrote: Ceri where abouts in south wales? Im in np44 if u need hand/me to do it
I'm in CF37 about 40 mins from you.
I have to get all the bits first but then sure! A hand is always welcome.
My shopping list is
Turbo/manifold
gasket/s
Oil & Filter
.. um anything else i need?
  1.9d turbo 306 engine swap to a berlingo joshed 7 6,100 25-02-2015, 05:28 PM
Last Post: xudlingo
  Newbie with a D Turbo Mike Southy 8 5,341 06-02-2013, 06:10 PM
Last Post: puglove
  306 d turbo swap/ sale pug_dturb 0 1,923 10-12-2012, 10:29 PM
Last Post: pug_dturb
