Threads: 9
Car Model/Spec: 2001 hdi estate
i believe that the c5 pipe needs cutting down a touch although dont do it off my say so as ive still not got round to fitting mine. i need the bottom pipe
Threads: 23
1
Again im not an expert but on mine it fit really well no probs at all I just had to cut the end down and remove the lugs on the side to be able to push my silivone elbow on further. But on my mates he had the same with his PAS pipe and the 406utp just didnt slot in the gap anywhere near as well. So im not really sure why there's a differnce unless the angle that it connects to the turbo is different on different turbos??
Threads: 24
Car Model/Spec: 306 hdi stage 2
I didn't even give it a thourght about the turbos the one I did it on last night was a k03 and my one that iv Gota do is a garrett so hopefully better fit do you know what turbo you have??
Threads: 117
119
Sounds like your joiner needs a bit of adjustment, ie cut half an inch off it and try again. Only if you've got a spare though lol!
Threads: 19
My bottom pipe was a pain to fit correctly .
Im guessing your having the same dilemna
I got the hacksaw and chopped a little bit off turbo end so it sat higher up and then it bended round everything alot better
Threads: 24
Does that still hold the
Boost ok once you chop the lip off
Threads: 23
1
It held well enough on my mates car when we fitting the cooler
Threads: 19
Mines holding well hasnt give me any problems
