Threads: 195
6
Car Model/Spec: 2000 Xs 1.8 16v
Hi all, for one I don't one if this is normal but I hope someone can post a light on it.
My 1,8 over revs. Best way to put it is, when you accelerate (Doesn't matter how much on the rev range) Then take you foot of the pedal to change gear, the revs carry on going for another 200rpm before dropping? Doesn't seem right as it is a pain when you up shift to the next gear having your car lagging behide?.
Anyone now if this is a problem or just a crap fuilt with these engines?
Threads: 136
11
Sounds like your idle control valve sticking open or you have an air leak somewhere
Make sure your inlet manifold bolts are tight also
Threads: 581
195
Throttle position sensor maybe.
Threads: 581
195
Its on the bottom of the throttle body. Easiest way to get it off is to remove the throttle body and flip it over. If you are handy with a multi meter and can find the correct values, you can take the plug off if you remove the inlet hose.
Threads: 195
6
Ive got a multi reader! pretty much got it all on there. Half of it I don't understand. What would I be testing for?
Threads: 581
195
I don't know unfortunately because i don't have the pin out data. I do on my other laptop but can't get that for you until Tuesday
Threads: 195
6
Theres no rush Niall I try not to drive it atm due to it letting me down on silly problems.
Threads: 136
11
Check for air leaks mate, much easier.
Get a cab of easistart and spray it around suspect areas. If the revs rise you have an air leak
Threads: 55
17
Car Model/Spec: 406 V6
Sticky throttle cable/spindle or an air leak I would suggest.
Threads: 4
sounds like throttle cable maybe could be wrong though try spraying some grease down it see if it works
Threads: 80
10
My bet's on a sticky throttle cable or duff spring on the tb itself.
Serious.
Threads: 195
6
Ive had a quick look the Tb springs back fine. but the pedal it's self is stiff. ?
Threads: 164
25
Car Model/Spec: Gti6
Given 4 thank(s) in 4 post(s)
Probably throttle cable if the pedal is stiff used to have the same with mine occasionally just spray some grease down the cable and see if it improves
Threads: 581
195
Yep definitely a bad throttle cable! New one from pug is P/N 1629G0 and is £50.58 which sounds a lot but believe me, cheap aftermarket cables are probably just as bad as your one now!
Threads: 195
6
Hmmm, is there a spring on the pedal arm its self? or is it driven by the cable and tb spring?
Threads: 581
195
Cable and TB Spring but whilst your down there, if there is a spring on the side of the clutch pedal, remove it. Can cause clutch wear issues.
