Turbo Adapter Plate Sheeting
Seen a few debates about various thicknesses between 6mm and 10mm.
What do I want, where do I get it?
eBay?
"Black Steel Plate 200mm x 200mm x 8mm Fixing-Mounting"
http://www.ebay.co.uk/itm/300903497094
[Image: %24(KGrHqIOKjoE9VfVrs11BSbWK9rzlg~~60_12.JPG]
"Black Steel Square Plate 300mm x 300mm x 6mm thick - Fixing-Mounting -Mild Steel"
http://www.ebay.co.uk/itm/291005439626
[Image: %24(KGrHqZ,!lwFJWvrv(-FBSbiku8-OQ~~60_12.JPG]
Any reccomendations / advice?
I used 10mm.
(02-11-2013, 01:36 PM)padge Wrote: I used 10mm.
Mild steel? eBay? Can't remember if I mentioned in your project but I really like your relocation manifold, looks top quality.
thanks, its mild steel, I just took my turbo to an engineering place, told him what I wanted.
Bet that set you back a bit!
So something like this:
Black Steel Square Plate 150mm x 150mm x 10mm Fixing-Mounting - Mild Steel
http://www.ebay.co.uk/itm/290970833950
[Image: %24T2eC16VHJGQFFh1eqDKiBSbWM,hkM!~~60_12.JPG]
10mm Mild Steel Disc 200mm Diameter
http://www.ebay.co.uk/itm/320928337266
[Image: %24T2eC16NHJGoE9nuQeS6bBQMh,Wfj,w~~60_12.JPG]
Black Steel Square Plate 300mm x 300mm x 10mm - Fixing-Mounting -Mild Steel
http://www.ebay.co.uk/itm/290997481550
[Image: %24T2eC16VHJGoFFvM0Mh,TBSbWHfc!yQ~~60_12.JPG]
cost me £40 Smile yeah should be fine.
(02-11-2013, 01:51 PM)padge Wrote: cost me £40 Smile yeah should be fine.
£40. Wow f**k me thats cheap!!!
Will 300x300x10mm be enough to make downpipe adapter and exhaust mani adapter?
Sod paying 40 quid! Any steel fabricators will have off cuts they'll be happy to sell you, I was lucky enough to be given a few bits last time I asked.
6mm is fine, 10mm is a pita to cut
(02-11-2013, 02:22 PM)zx_volcane Wrote: Sod paying 40 quid! Any steel fabricators will have off cuts they'll be happy to sell you, I was lucky enough to be given a few bits last time I asked.
So I'm still confused.. 6mm, 8mm, 10mm.. Have any spare? Blush
How are you going to be cutting it? Obvs thinner is easier and 6mm is plenty strong for plates.
If I was getting it got cheap or free I wouldn't turn down 7,8,9,10mm etc
It's just a bit of metal end of day to perform a simple function, doesn't need to clever or even brand new, could cut out of scrap if it'll clean up fairly good and is mostly flat
Paul fabbed my gearbox mani out of all sorts of old bits of scrap, reused old adaptor plates i made for other turbos for the end plates, old bumper bracket for support ...etc
I see, thanks dude, I just want to do it properly as I can't be arsed dragging the turbo out and having to refabricate if I can do it properly the first time around!
I don't know what I'm going to cut it with tbh.
What do most people use?
Might have a tool at work suitable for the job (big F-O grinder)! Tongue
Still need to sort this out for my adapter plate..
Would 100mm x 100mm x 6mm be large enough? Found a nice pack of 4.. £11.40 posted.
http://www.ebay.co.uk/itm/290738617400
[Image: %24(KGrHqFHJBUFJS+ilFmsBSbWLN!8D!~~60_12.JPG]
Or a pack of 2.. £7.00 posted.
http://www.ebay.co.uk/itm/300934434719
[Image: %24(KGrHqZ,!pIFHHFRnkl8BR45q9!RKQ~~60_12.JPG]
Or a pack of 2 150mm x 150mm x 6mm if 100mm isn't big enough? £13.24 posted.
http://www.ebay.co.uk/itm/290950705682
[Image: %24T2eC16ZHJIEFHSG5TupWBSbWLmOqp!~~60_12.JPG]
I got 10 on my td04 but then i used oxy torch to cut it lol. 6mm would be fine, and it would keep the turbo in closer to the engine.
Can't believe you're still debating this, crack on lad!
I think the ones CJ got done were 6 or 8mm and they seem to have done the job fine.
ive thrown away hundreds of pieces of flat steel away now i see people selling it on the bay ? ....business idea perhaps ?
(09-11-2013, 09:30 PM)zx_volcane Wrote: Can't believe you're still debating this, crack on lad!
Haha, pretty much sums up the 205's progress tbf.
Just stocking parts and driving/fixing/owning the 200SX.
Yeah, 10mm plate is fooking excessive!!!! It's also going to stick the turbo out like 5 miles out the back of the engine.
Only issue with 6mm is if you're welding straight to it, you can warp it easier than 10mm...
Thumbs Up turbo adapter xudlingo 3 2,840 30-08-2015, 12:37 PM
Last Post: Chairchild
  Flatting turbo adapter plates 306Puggy 5 3,991 11-11-2013, 04:36 PM
Last Post: martyn92
  Turbo adapter plates Dan! 25 13,337 04-04-2012, 09:07 PM
Last Post: Dave
