Threads: 208
60
Given 5 thank(s) in 5 post(s)
Right im about to run out and get some lowering springs for my Dt (as iv lowered the rear and it looks stupid,
Soooo they only have 30mm for a DT, No good
60mm gti springs to low
but they do have 55mm for 1.4/1.6/1.8 <<< will these be any good ??
Threads: 87
31
Given 1 thank(s) in 1 post(s)
Id get the 60mm GTi springs. DT is pretty much the same weight, maybe a bit less. If you get 55mm springs for a TU engine it will probably drop it a bit more, maybe 65mm.
Threads: 87
31
I beat mark, I beat mark :dance:
Threads: 208
60
hhhmm what about 35mm tu's?
Threads: 208
60
need to get it over cyclones with 55 profile 60mm gtis willl be to low?
And the arse is looking very irish atm need to take it apart again lol
TU's out the window then lol
Threads: 9
19
Given 3 thank(s) in 1 post(s)
It will go over cyclones at 60mm, trust me, it'll be fine, mine is definitely lower than 60mm and doesn't touch with 195/50/15's or 195/45/16's depending on the wheels I have on!
Threads: 22
Car Model/Spec: 306 1.4
It will be fine on a 60mm drop!
Threads: 82
27
It'll be more like a 50-55mm drop anyways with the difference in engine weights
