Need your help a bit quick - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: General (https://www.306oc.co.uk/forum/forumdisplay.php?fid=6) +--- Forum: The Couch (https://www.306oc.co.uk/forum/forumdisplay.php?fid=7) +--- Thread: Need your help a bit quick (/showthread.php?tid=1852) |
Need your help a bit quick - puglove - 28-02-2012 Right im about to run out and get some lowering springs for my Dt (as iv lowered the rear and it looks stupid, Soooo they only have 30mm for a DT, No good 60mm gti springs to low but they do have 55mm for 1.4/1.6/1.8 <<< will these be any good ?? Re: Neee your help a bit quick - Dan! - 28-02-2012 Id get the 60mm GTi springs. DT is pretty much the same weight, maybe a bit less. If you get 55mm springs for a TU engine it will probably drop it a bit more, maybe 65mm. Re: Neee your help a bit quick - mark_airey - 28-02-2012 Neee your help............or knee your help? ![]() Can nobody spell today?? ![]() GTi engine is heavier than the DT.....you won't get a 60mm drop using 60mm GTi springs on a DT Of you use the TU petrol ones though it will be on the floor! Edit, FFS, what dan said! Re: Neee your help a bit quick - Dan! - 28-02-2012 I beat mark, I beat mark :dance: Re: Neee your help a bit quick - mark_airey - 28-02-2012 Dan! Wrote:I beat mark, I beat mark :dance: Clearly on purpose too by the one sentence reply *quick, mash the keyboard* ![]() Re: Neee your help a bit quick - Dan! - 28-02-2012 mark_airey Wrote:Dan! Wrote:I beat mark, I beat mark :dance: I used 3 full stops! :geek: Re: Neee your help a bit quick - puglove - 28-02-2012 hhhmm what about 35mm tu's? Re: Neee your help a bit quick - mark_airey - 28-02-2012 ![]() Puglove - if you want a bouncy as f*ck ride then drash on, using TU springs will result in the spring rates being a f*cking mile off! the ride will be horrible and it will handle like shit! Go for the 60mm GTi ones IMO, it'll be fine, no such thing as too low unless the chassis is on the ground and you can't move! ![]() Re: Need your help a bit quick - puglove - 28-02-2012 need to get it over cyclones with 55 profile 60mm gtis willl be to low? And the arse is looking very irish atm need to take it apart again lol TU's out the window then lol Re: Need your help a bit quick - mark_airey - 28-02-2012 It will go over cyclones at 60mm, trust me, it'll be fine, mine is definitely lower than 60mm and doesn't touch with 195/50/15's or 195/45/16's depending on the wheels I have on! Re: Need your help a bit quick - Foxy-jim - 28-02-2012 It will be fine on a 60mm drop! Re: Need your help a bit quick - Midnightclub - 28-02-2012 It'll be more like a 50-55mm drop anyways with the difference in engine weights |
