clutch pedal switch...
What is this switches purpose does anyone no?
Most hdi's show up this fault wen codes are read obviously cant be important
Cheers james
[Image: av5ym8.jpg]
It's so the ECU knows when you dip the clutch to change gear, it tries to the match the revs for a smoother gear change. Not too important tbh.
Right o
not a bad idea I suppose.cant see it helping all that much anyway cheers
[Image: av5ym8.jpg]
Yeah I think it also tries to avoid stalling by chucking a bit more fuel in if you come off the clutch a bit quick when pulling away.
You could unplug it and see if theres any noticeable difference but I doubt it.
  Clutch pedal doesn't spring back as it should Moh 6 3,696 26-05-2015, 06:29 PM
Last Post: Moh
