Fuel cap cable snapped
So I need to replace the cable for the cap popper. It has snapped from the rear end under the wheel arch at the back. Before I do has anyone done this before and have any tips? Haynes is a bit vague with description !
I've removed a couple, it's just a simple cable, you only need to lift the carpet along that side and remove the rear arch liner for access iirc, then it's fairly straightforward.
Cheers mate. Stripped the interior out to find you get access from the wheel arch. Farce !
What are the chances haha. I was just about to post the same thing. Thanks this has helped a bunch Smile.
  Snapped Aerial Mark 2 2,649 08-09-2014, 09:20 PM
Last Post: Mark
  Snapped bonnet release cable Connor 9 6,144 10-12-2012, 11:05 PM
Last Post: megwan
  Snapped my door handle off.. hbomb1905 4 3,634 15-03-2012, 10:23 AM
Last Post: hbomb1905
