Snapped Aerial
Snapped Aerial
My aerial snapped off today whilst driving, which made a horrible noise on the roof as I assume it flipped over hitting the roof several times!! It has snapped really close to the base where it must have rusted through. Since it's rusty and so close to the base, I doubt I'll be able to get the remainder out to fit a new mast so it's probably easier to replace the base as well (and fix the rust on the roof around the base too while I'm at it).
Does the base simply unbolt from the inside of the car behind the interior light?
Thanks
(08-09-2014, 06:02 PM)Mark Wrote: My aerial snapped off today whilst driving, which made a horrible noise on the roof as I assume it flipped over hitting the roof several times!! It has snapped really close to the base where it must have rusted through. Since it's rusty and so close to the base, I doubt I'll be able to get the remainder out to fit a new mast so it's probably easier to replace the base as well (and fix the rust on the roof around the base too while I'm at it).
Thanks
You have to remove interior lights and there a nut tucked up in the top Wink
Thanks, thought that might be the case. I'll go to Peugeot tomorrow and see if they've got the parts in stock
  Do I need a new aerial for DAB radio? DonGonzo 1 2,870 15-04-2022, 07:29 PM
Last Post: Mighty306
  306 Cab aerial repair Aussie306Cab 0 2,761 19-01-2021, 03:40 AM
Last Post: Aussie306Cab
  Aerial change Aaron35 1 2,149 27-01-2014, 07:06 PM
