18-10-2013, 04:37 PM
As above are they the same? Can't get on to service box to have a look
Xud and Hdi Sumps
18-10-2013, 04:41 PM
no mate
00' 106 Indy - Moonstone - Sold
97' 106 XT 1.6 - Mayerling Green - Swapped 95' 306 P1 DT - Onyx - Scrapped 97' 306 P2 DT - Silver - Scrapped 97' 306 P2 DT - Onyx - SORN awaiting scrap
18-10-2013, 04:46 PM
Alright thanks for that
19-10-2013, 07:50 AM
Hdi is ally and XUD is steel. Steel is better because it doesn't crack when a peanut hits it.
19-10-2013, 08:19 AM
The sumps are all the same fitment wise, you can fit a hdi sump to an xud and an xud sump to a hdi.
Like facial hair said, one is steel and the other Ali If you try and fit an Ali sump to an xud without aircon and power steering at the bottom then you will have to cut the aircon mounts off the Ali sump for them to fit And obviously if you have air con you won't be able to fit a steel sump as the brackets aren't there
19-10-2013, 09:21 AM
alloy sump holds more oil
19-10-2013, 09:26 AM
Thanks everyone, someone wants to put an xud sump onto a hdi engine. Don't know if it has aircon or not but will find out, if it does is the bracket an important one?
19-10-2013, 10:09 AM
the aircon pump uses the bracket as supports
if you remove this you will have to change the aux belt length and reroute it
19-10-2013, 01:00 PM
Xud use Ali also all aircon models do
TD04 11mm Sedan, now 2.1 vnt
Sedan Project http://306oc.co.uk/forum/thread-5763.html Provence Dturbo Dead Blaze 1.6 Dead China 5dr '6 Death by cambelt failure Matt White HDI estate Death by wiring Sedan Dturbo aka triggers broom Diablo estate Dturbo Living dead |
Sumps XUD7 / XUD9 | ginge191 | 7 | 2,160 |
04-08-2016, 05:28 PM Last Post: Danny Wideboy |
sumps.... | ozonehostile | 11 | 3,140 |
08-12-2012, 03:50 PM Last Post: ozonehostile |
