water pump metal propeller?
hi guys
doing cam belt etc on my d turbo can you get water pumps with metal propellers?
if so could some one shed some light of the brand that makes them?
Everyone I've come across probably around 10 have all been metal. Only crappy VAG's come with plastic ones I believe.
Stage 2 XUD Sedan
dw10 cambelt kit by Gates has a plastic water pump blades
I put a QH one on mine and it had metal fins.
thanks guys i'll get on that monday then, when parts place is open Smile
Mines metal also bit was a cheapo so no idea what make
TD04 11mm Sedan, now 2.1 vnt
Provence Dturbo Dead
Blaze 1.6 Dead
  DW8 Timing belt cover / water pump bolt size? jamesgmg 13 10,936 06-07-2017, 03:41 PM
Last Post: Mighty306
  water pump help sb194114 4 3,189 25-03-2015, 10:28 AM
Last Post: cully
  water pump differences? ash23 1 2,117 11-06-2014, 05:20 PM
Last Post: ConorTRG
