1 dipped beam working other side not??!!?? isn't the bulb
Dont know If any of you have had this problem
before but can you help?
Found the problem guys
What was the issue? May help others in the future
Team Doesn't own a 306
Ye what was it. My xr3 doing same so could be similar issue
Venetian XUD ph2 heaven
Ph3 perv cab heaven
Black ph1 XUD died
Moonstone hdi stage 2
When it happened on mine, was a relay under the bonnet.
That was PH1 BTW.
fuse!
  Fog lights, new bulb ROBCAT 0 2,542 14-06-2018, 09:11 PM
Last Post: ROBCAT
  off side Electric window and door not working bluebenz1 1 3,380 01-05-2018, 10:07 AM
Last Post: pug306driver
  Ph1 replacing dual bulb headlight assembly with a single bulb H4 one The Coolest 9 5,365 13-11-2015, 04:48 PM
Last Post: The Coolest
