Help with a how to
Help with a how to
can anyone help me out with how to smooth my bonnet (debadge it)?
Need to weld a plate in place, then filler to smooth it off and paint. You will also need to smooth the grill
iv got the smoothe grille on order. is the other part hard?
Not hard at all if you can/know someone to weld a plate and if you know how to use filler
Where dd you order the grill from? I ordered one offline an it doesn't fit properly.
[Image: Foxy2.jpg]
You don't HAVE to weld a plate, there's a fair few ways of doing it, a metal plate behind would probably stop any filler etc. from sinking though
No you really do have to weld a plate in, take your badge off and you'll see what i mean
got mine off ebay for £10. what the best way to do it then because i can get someone to weld it easy.
Unbolt the badge, get a plate welded in and then use filler to get the final shape and smooth
great! thanks for the help, will be on the long list of things to do Smile
Definitely weld the plate. If you don't the vibrations of shutting the bonnet will crack the filler!
[Image: Foxy2.jpg]
Users browsing this thread: 8 Guest(s)
