29-09-2013, 05:27 PM
Help please people anyone can't bleed rad
3.0 306 v6
29-09-2013, 05:36 PM
2lt coke bottle fill it with water stick it in the hole, open the bleed points one by one starting from the bottom and working up, keep open until you get a constant stream of water.
Also wrong section.
29-09-2013, 05:41 PM
(29-09-2013, 05:41 PM)bradh511 Wrote:(29-09-2013, 05:36 PM)Tom Wrote: 2lt coke bottle fill it with water stick it in the hole, open the bleed points one by one starting from the bottom and working up, keep open until you get a constant stream of water. It's easy as above make sure the bottle has a good seal mate. Is the system pressurizing tho?
29-09-2013, 06:33 PM
Sounds like your not doing it right, or it doesnt need bleeding and you have other issues.
29-09-2013, 06:46 PM
Hi again. heater get hot ... Just seems like it gets to hot to quick so am gessing it just fans so will fit some and take her for a test run
29-09-2013, 07:17 PM
How old is your radiator? There crap even new
