Wanted: URGENT: Offside Wishbone for GTi6
Hi,
Has anyone got an offside wishbone kicking about?
It has to be for a GTi.
I need one ASAP please.
Thank you,
Eli x
Has to be for a gti? Why? You should just ask for 16 or 18mm
It's a phase 2 as well, could be either Undecided I'm willing to bet it's a 16mm though!
(21-09-2013, 03:40 PM)Connor Wrote: Has to be for a gti? Why? You should just ask for 16 or 18mm
yeah i think they're same tbh . . . . .
Well i've bought the ball joint from ECP under the registration and was specified with/without PAS i believe. Visually it seems to match quite well, but than again, i'm looking at 2mm Doh
You can get the old one out, just
With great difficulty.
If you have got a non pas one, you will have positive camber. Have fun with that.
(21-09-2013, 06:35 PM)Niall Wrote: If you have got a non pas one, you will have positive camber. Have fun with that.
And what's the best way to tell which is a non PAS one?
given the picture Phil has provided - is this a non or PAS wishbone?
[Image: attachment.php?thumbnail=10353]
You need to measure the balljoints, if yours turns out to be 18mm and you put in a 16mm - you are f*cked. Hopefully you find something buddy! Xx
Why did i leave my vernier on the island Doh
Measuring tape it is!
The wishbones are all the same. The difference between non pas and pas ball joints is the length of the plate. The pas plate is longer for more camber.
(21-09-2013, 07:02 PM)Niall Wrote: The wishbones are all the same.
Same left and right? After ball joints are removed?
It's quick to measure ball joint size by slipping a spanner over them, no need for verniers.
No not from side to side. I meant across all models of 306.
My question was side to side sorry, are they?
And sorry for the off topic!
With the p bush removed they are the same side to side.
[Image: sig.jpg]
  Wanted: China blue offside door handle DeeTurbo 0 1,908 03-05-2016, 12:54 PM
Last Post: DeeTurbo
  Offside front arch liner/cover LewisG 5 3,500 21-05-2014, 12:23 PM
Last Post: bashbarnard
  Wanted: Phase 1 offside rear light unit Curt 11 5,829 28-02-2014, 06:48 PM
Last Post: Anton
