Rear brake wheel cylinder which one opps its a caliper
Hello Im changing the front rubber brake hose on my front caliper. So Ive been un-screwing the nipples etc.
But one rear brake wheel cylinder the nipple snapped as they do with age. But which brake cylinder do I need there diffrent ones and makes.
Mine the 306 hdi with abs and rear disc brakes on a 1999 model.
Its a caliper being rear discs.
Rear calipers are all the same on these, ones off a 106 will fit and I believe 206 too.
My ones from Kris last week came off a 106 beam.
As said, all rear disc callipers are the same^^
Depending on the condition of the caliper I might have it extracted the broken nipple.
  Do I buy? rear brake pipe corroded, covered in grease or other material pipes Charlie0 3 12,891 18-04-2019, 10:14 AM
Last Post: Mighty306
  rear wheel arch Quietone 4 4,756 16-04-2019, 11:42 AM
Last Post: welshpug
  Uneven brake drag on rear wheels balkan_bozo 2 3,868 21-10-2018, 11:10 AM
Last Post: balkan_bozo
