7J Et20 wheels
7J Et20 wheels
Will 7J Et20 wheels fit fine on the front
I'd imagine so, yes. Only possibly problem I can see is maybe needing 5mm spacers if running coilovers, but should be fine.
I may be wrong but will they not be closer to the arch?
The offset is slightly higher than standard so will sit closer to the strut, the width should be fine for the arch. If not it's an easy job to roll the arch. Should be fine though, they're not very wide.
I have just finished painting the car so i really don't want to roll them at this stage, I have got a plan on how to fit 8" on the rear without rolling them tho...
We're talking just 2mm further towards the arch, so it probably won't be a problem.
If it is, rolling the arch just a tiny amount with a proper arch rolling tool and a heat gun is extremely easy.
