Clutch cable help!
Had the clutch cable disconnected gear box end on a 306 DW8 and pulled the cable, it's clicked a few times and now is too short to go back on the clutch arm.
Is there anyway to release the self adjuster to get the cable length back?
(08-09-2013, 12:36 PM)jamesgmg Wrote: Had the clutch cable disconnected gear box end on a 306 DW8 and pulled the cable, it's clicked a few times and now is too short to go back on the clutch arm.
EDIT: Sorted, cable had come off the clutch pedal, whoops!
hi my wife's 306 cabriolet judders when you select a gear when stationary any ideas or solutions
(13-09-2013, 03:02 PM)pinkpug Wrote: hi my wife's 306 cabriolet judders when you select a gear when stationary any ideas or solutions
More info; when you pull away? When you select? Any crunching? Stiff clutch pedal?
when the car is still and u select gear the wheels judder just slightly clutch not stiff and no niose
  New clutch cable needed jcsh 3 4,484 11-02-2021, 05:01 PM
Last Post: ekjdm14
  Citroen ZX 1.9 TD Clutch Cable drew 0 2,598 17-05-2019, 12:58 PM
Last Post: drew
  clutch cable routing carlukepeugeot 4 5,210 29-10-2016, 08:24 PM
Last Post: carlukepeugeot
