Wanted: 306 door loom with 21 wires
Anyone able to help me out? In desperate need of these for both doors
Thanks
fix it in meantime?
second hand looms could be no better or worse!
I'd defo spend a few hours soldering and shrink wrapping your existing ones over fitting second hand ones as the chances are your gonna have the same problem later if not immediately.........either that or but new ones
Its so much easier just to replace the entire loom
(04-09-2013, 06:21 AM)Daniel306 Wrote: Its so much easier just to replace the entire loom
it is if you buy a new loom which are hugely expensive and are still wired too short.
personally I would say even with a new loom, cutting open the boot and soldering in a small length of wire on a couple of broken ones is simpler than doing the entire loom
The plug is too far gone there's not enough wires there to work with "/
I've found a passenger one on eBay but need a drivers "/
what phase is this for??
I got a ph1 drivers loom/plug. been repaired.
2 but that shouldn't matter
As long as there's 21 pins in it
Iv done both ways, changing the lot is quicker and far easier than trying to fit a new plug
Bump have a passenger side just need drivers now Sad
Bump up
I have one il check wires tonight
[Image: J5hxCcC.jpg]
  Wanted: Drivers Door Loom Jama 4 2,880 12-07-2014, 04:02 PM
Last Post: mspdan
  Wanted: Door loom Daniel306 8 4,240 02-11-2013, 10:36 PM
Last Post: Daniel306
  drivers door wiring loom Nadine 11 5,176 01-07-2013, 12:11 PM
Last Post: CJ_Derv
