dturbo egine in. Just turning over.
So my friend just dropped in a dturbo engine cause his old one went BANG Tongue Anyways, its turning over perfect, but just not starting! Any ideas?
[Image: DSC_0054.jpg]
Bled the fuel system?
(28-08-2013, 02:35 PM)Tom Wrote: Bled the fuel system?
Still useless round engines so how exactly? (even though i took a dturo out of a breaker i got!! Cant wait to drop it into my nad Big Grin )
fueling
stop solenoid
you only really need fuel, air and compression. Triple check air flow and fuel flow is sufficient ThumbsUp
crack off the unions one turn on the injector lines (injector end), and crank the engine til it pisses out the top, lock the unions back tight, make sure all 4 bleed fuel out
(28-08-2013, 02:38 PM)ginge191 Wrote: ^^^^
fueling
stop solenoid
right we'll check the fuel flow Smile how do we check the air flow? Smile
(28-08-2013, 02:57 PM)Darren123 Wrote: right we'll check the fuel flow Smile how do we check the air flow? Smile
easiest; disconnect any intercooler/piping and leave the inlet manifold open where the top mount usually sits. Obviously make sure there's nothing around it to get sucked in lmao
and TBH, it's easiest way to get to the unions also. just leave any intercooler/turbo disconnected from the inlet
fair enough Smile and what am i looking for when we disconnect um? just to make sure there's an air flow?
yeh, you can feel the inlet sucking...
just crack the unions off half a turn from tight, turn engine over, watch diesel piss out, tigten them up.
If they don't bleed fuel, tighten them ALL up and undo one line at a time
Crack em all off hold it at full throttle and crank over til its squirting everywhere, tighten then start aha
If the bleeding doesn't work check the stop solenoid on the pump. Are you going Lucas ----> Bosch?
HDi Cabby Project Click
Crack one of the injectors off and turn the car over and see if fuel comes out
3 x Peugeot owner.
1996 106.
1996 306 D Turbo S.
1994 Mercedes Benz 320E.
1997 306 GLX.
What pump is on the new motor, if its lucas, and it still has an immob chip on it, it wont work out the box.
If its bosch / the same pump as old engine, just needs bleeding as above Smile
(13-09-2013, 02:31 PM)darrenjlobb Wrote: What pump is on the new motor, if its lucas, and it still has an immob chip on it, it wont work out the box.
On the Lucas stop solenoids, are they a simple change or is there more to it?
3 x Peugeot owner.
1996 106.
1996 306 D Turbo S.
1997 306 GLX.
The immob ones are covered with a steel shroud, you can cut the shroud off and either change the solenoid, or wire the one thats there manually, but you cant just swap complete immob lucas pumps as the chip on the back of the pump wont match the cars immob, so it wont open the solenoid.
(13-09-2013, 07:26 PM)darrenjlobb Wrote: The immob ones are covered with a steel shroud, you can cut the shroud off and either change the solenoid, or wire the one thats there manually, but you cant just swap complete immob lucas pumps as the chip on the back of the pump wont match the cars immob, so it wont open the solenoid.
This is what is was Smile all sorted now Smile
Thought as much lol.
  No oil light when turning ignition key over 306__xrdt 9 6,895 01-05-2013, 01:01 PM
Last Post: 306__xrdt
  Screetching on boost after turning down wastegate 306Puggy 15 8,457 12-12-2012, 10:55 AM
Last Post: 306Puggy
  Whining when turning davalav 8 6,063 24-11-2012, 05:29 PM
Last Post: davalav
