Fan Belt Squeal!
My fan belt is squealing, and it's very high pitched, I was wondering if there is a quick fix until I can get it looked at.
[Image: Untitled_zps2ed48460.png]
Tensioner needs to be tightened.
It doesn't feel slack at all though.
There should be 2 cm of movement under firm thumb pressure. They do have to go quite tight to stop the noise.
Bar of soap? Wd40 or the likes? That'll shut it up for a bit!
Always make sure you cant turn the belt more than half way round once fitted and tightened, that shows you enough tension has been applied.
Alright cheers!
  Massive belt squeal Nathan1305 3 2,934 12-03-2015, 05:19 PM
Last Post: Nathan1305
Exclamation Belt slapping wildly - belt tensioned - pics added ginge191 57 50,421 25-04-2013, 09:22 AM
Last Post: Mattcheese31
