Partner/Berlingo P Bush
#31
(05-09-2013, 04:47 PM)tigerstyle Wrote: Is there a guide here for fitting these? I recall there being one but can't find it.
Failing that is this http://www.306gti6.com/forum/showthread.php?id=22963 pretty much all you need?
Might fit mine at the same time as my new front shocks seeing as the droplinks will be of and everything will be a little easier hopefully.
My pitcrew Connor will be fitting mine soon Smile
Best of luck fitting all your bits Smile
[Image: siggy1.jpg]
I'm a bit stuck with re-assembling all this guys...
What's the best order to slot it all back together? I've put the ball joints in first and am then trying to get the PBush tight then the front bolt.
I read the GTi6 Guide again and perhaps I should strictly follow the reverse is removal etc etc. and have the order as
1. Tighten PBush
2. Tighten front bolt
3. Tighten ball joint
I'm having a whale of a time trying to wrestle it all back in there! It's not that easy is it? And I lost my 2 month old Gearbox oil through the whole thing flopping around on me Sad I also think I set my angle of the PBushes a bit too high (I'm lowered 30MM) so might try and flatten though angle to help get in back in there.
Just read to remove droplinks to help remove stress from the anti roll bar, and I have both sides jacked up equally too.
Just seen a G clamp might be needed to squash the PBush down to the chassis too.
(21-09-2013, 08:00 PM)tigerstyle Wrote: I'm a bit stuck with re-assembling all this guys...
1. Tighten PBush
put the balljoints in last mate, also as said before, take both the droplinks off, makes it a lot easier with the arb clamps. .. .Smile
yeah flipping...must be a right ball ache trying to get it in with the ball joint first, no wonder ya struggling!
Smile Got the drivers side in with Ball joint in first (but wouldn't recommend doing it that way!)
And had to remove the ball joint on passenger side to get it all slotted in, but the nice new greased ball joint just fell out when I undid the bolt so no risk damaging the new joint with the splitter.
Definitely recommend a big g clamp to squash the PBush down into place and then the roll bar mount on top of it after, that helped a lot!
Good stuff it's finished, feel better now and worth the aggro?
[Image: siggy1.jpg]
How has everyone found these p bushes then? About to get them but just wondering if they are worth it ? Smile
[Image: 65613_10200761612710317_1548698655_n_zps68c27004.jpg]
CONVOI EXCEPTIONNEL
(08-05-2014, 09:29 PM)martyn92 Wrote: How has everyone found these p bushes then? About to get them but just wondering if they are worth it ? Smile
yup worthy upgrade dont forget the m10 bolts though as they arnt std thread Wink
Awesome, will get them bought then Smile
CONVOI EXCEPTIONNEL
Wink
http://306oc.co.uk/forum/thread-13188-po...#pid416521
Yep look pretty good in there. Sold!
CONVOI EXCEPTIONNEL
Anyone else noticed this have shoot up in price to £30 each Sad
£65 a pair for the same listing now. Glad i got mine when i did.
f*ck, I wish I'd bought 2 pairs now as I put the pair I'd bought for the Rallye on the 'state.
3523 83, they are only £26.22 each including VAT and before discount direct from Peugeot.
wow glad i got mine when i did
http://www.ebay.co.uk/itm/FIRSTLINE-FRON...43b21491b7
cheapest ive found since on the net and £16 each on trade at my local factors
The ones I bought for other half recently went up to £60
How are these shaping up after a bit of use?
For £10.99 delivered for a pair - I'm not expecting much.. be they have to be better than the earlier variety no?!
http://www.ebay.co.uk/itm/for-Citroen-Xs...SweW5VcC50
had about 10k on mine, still fine, genuine ones though.
They're the ones I run on mine. Coverd almost 15k and still fine. Admittedly I average about 50%motorway miles
mine are fine still way firmer than the saggy std ones
GTI6 Info
Thanks - sounds like they are worth a punt!
http://d2pautoparts.com/front-suspension...52383.html
£1 cheaper here direct from the company rather than eBay
this should be pinned..
/Toseland
  P Bush PocketFighter 7 2,567 09-08-2016, 04:47 PM
Last Post: PocketFighter
  p bush upgrade tuttyboy84 9 2,975 14-02-2015, 06:25 PM
Last Post: tuttyboy84
  berlingo/partner hubs on hdi gavxud 4 1,523 11-02-2014, 12:23 PM
Last Post: gavxud
