16-08-2013, 09:05 PM
the rear bang from back near side im right in saying the shock has had it, I understand they easy replace. any guidance guys would help.
banging from rear back wheel when going over bumps
16-08-2013, 09:07 PM
Moved to the right section. Banging could indicate that the rear beam is broken (bearings have gone) and needs replacing. Is there any camber on the rear wheels?
(This post was last modified: 16-08-2013, 09:08 PM by himindoors.)
16-08-2013, 09:12 PM
are you sure it's not rear beam mounts?
Could be one of the beam mounts as above, i have just changed all of mine and now no more knocks.
16-08-2013, 09:15 PM
not sure don't handle odd but will get my mate to check it over, thanks for the help guys, the parts arnt too expensive I understand
17-08-2013, 10:34 AM
17-08-2013, 10:40 AM
rock the car in reverse with handbrake on...if it knocks, likely beam mounts.
17-08-2013, 10:49 AM
if the beam aint cambered and shocks are ok...99% of time it be mounts!
17-08-2013, 12:38 PM
anti roll bar! i bet the end plates are lose!
17-08-2013, 12:39 PM
I would say beam mounts
21-08-2013, 01:42 AM
Its either the rear mounts, ARB end plates where the bush has worn out possibly or similar and the last one is the lower shock bolt nut, this has been known to come loose and cause knocking.
22-08-2013, 06:14 PM
there is another possible cause... loose spare wheel, will knock against the boot floor over some bumps, mine's doing it atm, the adjuster is solid so it's soaking in plusgas until tomorrow
Project: Formula Peugeot
23-08-2013, 08:15 PM
24-08-2013, 07:16 AM
have a look at the shocker bushes,
they sometimes move off them
25-08-2013, 07:39 PM
(This post was last modified: 25-08-2013, 07:40 PM by himindoors.)
well the banging was coming from a tyre cage, with a flat tire in rack. Der what a muppet. :-(
(23-08-2013, 08:15 PM)himindoors Wrote:(22-08-2013, 06:14 PM)John1.4 Wrote: there is another possible cause... loose spare wheel, will knock against the boot floor over some bumps, mine's doing it atm, the adjuster is solid so it's soaking in plusgas until tomorrow well the banging was coming from a tyre cage, with a flat tire in rack. Der what a muppet. :-(
26-08-2013, 10:43 PM
Glad you found the problem, least if you hear any other knocks again then you know what stuff to look out for.
| rear wheel arch | Quietone | 4 | 4,987 |
16-04-2019, 11:42 AM Last Post: welshpug |
| Rear Disk Wheel Bearing | daveylennon93 | 21 | 16,567 |
06-03-2017, 11:24 AM Last Post: dt_ |
| Weird banging noise when braking, advice needed. | Spoonaltap | 19 | 9,077 |
27-01-2017, 05:52 PM Last Post: Spoonaltap |
