Can't get my angel eyes/HIDs to work?
Plugged the grey plug into the socket, and the indicator plug in but I get an odd pattern of lights?
Drivers side:
Sidelights: halo rings, 3 small yellow lights go on as expected along with the innermost smallest projector lens
Dipped beam: nothing changes from the sidelights setting but there is an intermittent fizzing noise coming from the light unit and I can't tell where it's coming from, no visible causes of shorts from what I can see
Main beam: same as sidelights but the non projector high beam does come on
Passenger side:
Sidelights: nothing except the innermost lens lights up
Dipped beam: the dipped projector lens lights up but nothing else apart from the innermost sidelight lens
Main beam: the non projector lens lights up along with the others
Really have no idea what's going on, all connections are secure and tight but :S
Thanks
Any pics if the wiring, it's a DIY job to get the halo working so they might have wired it wrong
They came of my car. Worked fine for me..
What phase is your car?
sounds like bad connections
(09-08-2013, 01:05 PM)Matt Wrote: Any pics if the wiring, it's a DIY job to get the halo working so they might have wired it wrong
Ill get some pictures after dinner Smile as Sean said they worked fine for him, they came off his car :p Mines a ph3 hdi, same as his
(09-08-2013, 01:14 PM)Piggy Wrote: sounds like bad connections
I was going to clean the connection sockets would that be any good?
Have you run 100w bulbs before?
HDi Cabby Project Click
  HIDs rocker8742 3 2,713 30-01-2013, 10:03 AM
Last Post: rocker8742
  HIDs Connor 6 4,086 24-11-2012, 01:13 PM
Last Post: Connor
