can someone shed some light of this
hi has anyone got any ideas to why this p bush looks like its being pulled of the lower arm, this is the o/s. thanks
[Image: WP_000353.jpg]
cant see much there pal but is the top bolt/nut in place?
yes mate top bolt/nut is there, but compared to the other side it dont look right.. maybe its just me being paranoid
n/s bush
[Image: WP_000348.jpg]
That definitely looks as if its being pulled off. Take the arm off and give it a good inspection. If that IRS whilst you are driving it could be horrific!
my concerns exactly, best thing is both lower arms are brand new & came with the bush attached. thanks
No chance the subframe is out of shape? If they're new wishbones i'd assume there's a manufacturing fault tbh.
i can't see any damage to the sub frame, here is a better view of the lower arm.
i gonna take it back to the shop where i got it from & get it replaced..
[Image: WP_000355.jpg]
That's definitely coming off. No two ways about it.
When you put the new one on measure te distance from the wheel-arch on both sides to give a better idea of if the subframe is straight Smile
Wink
cheers for that.
Well got a replacement lower arm Smile it turns out the old one was smaller arm some kind of manifacturing fault :/ All sorted now though. Thanks for the quick replys
Thats odd.
Theres a lot of lower arm issues coming out of the woodwork lately :/
Glad you got it sorted Smile
I suppose thats what you get for not buying dealer parts.
It shouldn't be the case though. If people are selling parts such as this they should be fit for purpose. What has happened there is a serious safety risk.
I'd be inclined to escalate it.
Glad to help. Smile
Easiest way to avoid this is to always compare old parts to new before fitting.
