Wastegated TD04 setups
Has anyone got any pictures of how they put on the wasted to the clocked TD04. I'm having trouble getting mine to fit and not hit the steering UJ or being at suck an angle it won't open?
I'm sure I will work it out tomorow but I'm tired and been working all day so my minds not quite with it right now.
Cheers guys
Stage 2 XUD Sedan
I would share mine, but it snapped off, so it clearly wasnt strong enough!
I had to make up a bracket for my wastegate on the t25, i could put a pic up of it if its any help to give you an idea.
i can take a picture of mine on thursday for you when i remove the turbo
i cut the TD04 bracket in half and am only using one bolt to hold it in place (seems very secure tho)
306 XUD9 gt2052s
306 hdi stage 2 (hdi tuning)
205 STDT -new project
i'd send a pic of the one i've just bought but lightning killed my pc yesterday Sad
(05-08-2013, 10:56 PM)rryan Wrote: i can take a picture of mine on thursday for you when i remove the turbo
Thats what i done, sheered off eventually Sad
ummm i might revise it then, maybe drill and tap another hole somewhere
306 XUD9 gt2052s
Which manifold have you used? I used the gt15 manifold and the wastegate sits underneath the turbo. Ill try and find some pictures if I can find them
Its not a very good picture but I made up a bracket from the unused water line and one of the original waste gate holes. Also had to gut down the wastegate arm a little too. May help?
gt15 manifold
[Image: 20130704_205247_zpse1a29d65.jpg]
[Image: 65613_10200761612710317_1548698655_n_zps68c27004.jpg]
CONVOI EXCEPTIONNEL
  Post your relocation manifold setups. silverzx 16 10,179 11-07-2014, 09:09 PM
Last Post: silverzx
  Compound turbo setups?? Craigus 24 19,680 26-09-2013, 12:16 PM
Last Post: darrenjlobb
