All mech pump for dw8 semi ecu
Currently on a lucas and giving trouble, 206 my02, is there an all mech bosch setup it will run without any custom parts? xud na? Do the lines from an xud fit and does the pump bracket have holes for a bosch? Car is far away from me so cant go out and look lol
(01-08-2013, 08:52 AM)con67 Wrote: Currently on a lucas and giving trouble, 206 my02, is there an all mech bosch setup it will run without any custom parts? xud na? Do the lines from an xud fit and does the pump bracket have holes for a bosch? Car is far away from me so cant go out and look lol
There is a direct swap DW8 fully mech pump chap, need one from an early dw8, the EARLY DW8 206's use the, however the late 306's dont, and the ecu controls timing and egr etcetc. typically i scrapped one the other day with one! that said xud NA pump will work fine....
I have a NAD bosch pump with lines in the shed...
  Lucas Pump: mechanical or semi-ecu controlled? andy_diesel 3 3,517 23-11-2016, 05:00 AM
Last Post: Dave
  Semi ecu pump to standard advice bashbarnard 7 3,462 17-12-2015, 06:45 AM
Last Post: bashbarnard
  Semi ecu controlled pumps Danny2009 3 2,758 24-10-2013, 08:18 PM
Last Post: 306Puggy
