20-10-2013, 02:43 PM
What's the differance between these?
What bit is controlled exactly
Semi ecu controlled pumps
24-10-2013, 08:15 PM
Yeah the advance is controlled by the ecu. You can drive without the ecu but it will be horrendous, stuck in full advance. You can still shim the timing piston though
24-10-2013, 08:18 PM
Yeah I smashed one of these up, the leverset, lda, gov cradle, plunger and associated gubbins can all be used, just the whole thing itself that is useless due to the stupid mechanism.
| Lucas Pump: mechanical or semi-ecu controlled? | andy_diesel | 3 | 3,835 |
23-11-2016, 05:00 AM Last Post: Dave |
| Semi ecu pump to standard advice | bashbarnard | 7 | 3,875 |
17-12-2015, 06:45 AM Last Post: bashbarnard |
| FAI Water Pumps | RAW | 12 | 9,773 |
18-02-2015, 12:13 AM Last Post: vinny |
