Brake spanner size ?
I'll be changing my rear beam on the weekend, want to make sure i got the right tools before i start, i need to buy a brake spanner to undo the brake lines, anyone know what size i need and will i need more than one size ?
Vise grips will do the job if your worried about a normal spanner slipping.
16 and 11mm possibly a 13 somewhere
[Image: av5ym8.jpg]
11mm Smile Make sure its a proper brake pipe spanner and not a normal one. Also, start getting them soaked now!
(16-07-2013, 07:49 PM)Niall Wrote: 11mm Smile Make sure its a proper brake pipe spanner and not a normal one. Also, start getting them soaked now!
The 11mm side goes into a bigger size, converted mine to discs few months ago
[Image: av5ym8.jpg]
The flexihose you need to remove to get the beam off is 14mm and 17mm iirc
use special plumbers grips, the ones that grip harder the harder you try and turn it...crack it off with those then normal spanner
but a good brush and soak now will do wonders
Get a proper 6 sided brake pipe spanner I got one for a few quid off ebay best tool I bought for brakes
http://item.mobileweb.ebay.co.uk/viewite...0944146982
Link might work im on my phone lol
iv always just used a normal spanner :dunno:
11mm...my brake spanners do 10mm and 12mm :/
Actually 10.5mm so be careful about rounding. Odd sizes...
There shit dont bother, mole grips i had to use. Actually snapped mine they were that tight
TD04 11mm Sedan, now 2.1 vnt
Provence Dturbo Dead
Blaze 1.6 Dead
I've still not got mine out the calipers on the spare beam I wanted to rebuild. Ally and steel don't mix to well after 10 years together.
all of mine rounded with a normal spanner. Definitely get the proper one or use molegrips
(16-07-2013, 08:15 PM)aggyj17 Wrote: Get a proper 6 sided brake pipe spanner I got one for a few quid off ebay best tool I bought for brakes
Thanks for the link I bought the spanner you linked to and found it to be stronger than the one I had. It finally got the pipe union off without rounding it.
No worries mate. That's the one ive got and never had any problems.
The one I had before looked nice but it kept splaying out when I put any force on it.
  Brake spanner size Dum-Dum 22 10,881 22-09-2013, 06:57 PM
Last Post: Frosty
  Brake Bleed Nipple size Kwik 20 10,568 10-11-2012, 05:10 PM
Last Post: Kwik
  Brake hose thread size samass 1 1,994 02-04-2012, 10:18 AM
Last Post: samass
