Cheap brand new Bosch injectors! . . . are these for a DT?
i'm guessing there're not and are for the XUD8te . .can anyone confirm? . . . . .
http://www.ebay.co.uk/itm/PEUGEOT-205-3 ... 943wt_1410
xud8/9 injectors should be the same no?
Dan! Wrote:xud8/9 injectors should be the same no?
just looking at break pressures and i'm not sure mate, that's an awesome price for a set though if it is eg!!!
Yeah very good price imo. I was jut thinking becaue my 205 wa an XUD7te and I just banged the xud9 boch ve and xud9 injector onto that just fine.......
Dan! Wrote:Yeah very good price imo. I was jut thinking becaue my 205 wa an XUD7te and I just banged the xud9 boch ve and xud9 injector onto that just fine.......
yeah i've just got it in my head that xud9 were 175break and the others were lower . . . Hmmmmm
also Dan send me your paypal as i don't do online banking mate . . . . .also got a little surprise for ya . .Wink
XUD9s use DN0SD306 - those are DN0SD299 Nozzles... Break pressures are possibly different to, you wouldn't notice it though... You'd get good gains from just a new set of injectors...
But saying that, my injectors are out of the 182k mile XTDT, and have done easily 30k in my car... And still work and pull fine with no hazing on idle... So frankly... I dunno if there's any point in replacing them unless they're jammed.
cheers for the info Ruan . . . .mine misfires like a lady garden when cold, could be a whole host of other things like but ya know . . . . :roll:
Glowplugs, timing?
Usually injectors are if it hazes continually, runs like a sack all the time, misses no matter what you do...
Ruan Wrote:Glowplugs, timing?
yeah i wasn't really thinking of replacing them but that seems a great price . . . . . .it's probably a glowplug in my case, one is crossthreaded and i couldn't replace it without fear of it snapping . .Smile
If it's missing on one cylinder, then yeah, probably that cylinders glowplug is f*cked... In which case, either drill it out, or just leave it alone and put up with the missing in the morning, maybe give it a bit more static timing... That'll help getting it running on all 4 quicker, and everyone loves a bit of injection clatter on a cold morning, makes you feel like more of a man with what sounds like 4 ball peen hammers smacking the cylinder head for the first 15 minutes in the morning Wink
If you want to check your injector on that cylinder, get out a screwdriver, place it on the injector body and stick it in your ear, if the needle is jamming, then you'll hear it in comparison to the other injectors... If not, then they're probably fine, as I've mentioned, my injectors have probably done over 200k miles, but they're still fine seemingly...
You can just get new nozzles if you want... DN0SD306 Bosch Part No: 0 434 250 167
I think they're on ebay for about £23.50 each... Which does seem expensive, but at least you know they're genuine Bosch nozzles...
Whats the difference from DN0SD299(a-b-c) and DN0SD306 nozzles?
I see that they are both listed for the XUD9 in the 93 to 97 Pug306..
Are the DN0SD306 just updated 299's?
Edit.. Found an Answer, Sorta! http://www.eng-tips.com/viewthread.cfm?qid=84264
Although, does not explain the 299 to 306 difference.
Suzuki Santana Vitara 1.9 Td (Xud9) 3Dr
Corrr they were a bargain! Cost me half that to refurb some!
[Image: 20120704_212316.jpg]
Big Grin Bosch injectors Niki 12 8,681 22-07-2017, 12:20 PM
Last Post: Niki
  Are KCA 17S42 Bosch injectors rated at 175bar ok for my modified XUD? 399road 4 3,634 11-04-2017, 03:33 PM
Last Post: 399road
  1.9 Bosch injectors Leeblair98 2 2,578 27-04-2016, 09:39 AM
Last Post: pioneer DJ paddy
