Painting skirts query
I've finished the lacquer on my skirts but one doesn't have the gloss finish.
Can I just put more lacquer over (already hardened) or does it need stripping back again?
How do you mean not a gloss finish? As in the lacquer has orange peeled?
seems odd that it dont have a gloss finish!?
You will need to flat back the lacquer. use some 1000...wet...that will give the new layer something to grab on to!
If you don't have enough lacquer on thus causing a matt effect, do not use water to flat it back. The paint underneath will be porous and despite it looking dry, it will still contain water, and ruin your lacquer as it dries.
Yea as in there isn't enough lacquer on one (was running out to the end). So it hasn't completely covered with a thick coat. (Still had 2/3 coats but hasn't finished very well ). Can get better pics tomorrow
Left side is duller...
So it's not advised to just coat it again now?
And if I rub it back use dry grit just down to the paint?
Just use dry 1000 grit and go over the whole skirt, don't have to take the paint off just scuff it up to take the shine off so the next coat has something to stick to
Team Doesn't own a 306
Sweet saves 40 odd quid on paint,
Ill do this next week.
Cheers for the tips guys!
  Painting/wrapping interior trim Iceman299 4 3,568 04-10-2015, 04:44 PM
Last Post: Slam Wagon
  Painting outside blaze_the_6 10 5,818 09-11-2014, 06:15 PM
Last Post: blaze_the_6
  Spoiler DIY Painting Advice MY95 14 9,366 16-01-2014, 06:30 PM
Last Post: kentiiboii
