Bosch injectors and lines
The following warnings occurred:
Warning [2] Undefined variable $unreadreports - Line: 31 - File: global.php(961) : eval()'d code PHP 8.3.32 (Linux)
File Line Function
/inc/class_error.php 157 errorHandler->error
/global.php(961) : eval()'d code 31 errorHandler->error_callback
/global.php 961 eval
/showthread.php 28 require_once
Warning [2] Undefined array key "thx_active" - Line: 275 - File: inc/plugins/thx.php PHP 8.3.32 (Linux)
File Line Function
/inc/plugins/thx.php 275 errorHandler->error_callback
/inc/class_plugins.php 142 thx
/inc/functions_post.php 917 pluginSystem->run_hooks
/showthread.php 1122 build_postbit
File Line Function
File Line Function
File Line Function
File Line Function
Warning [2] Undefined property: MyLanguage::$thread_modes - Line: 43 - File: showthread.php(1651) : eval()'d code PHP 8.3.32 (Linux)
File Line Function
/showthread.php(1651) : eval()'d code 43 errorHandler->error_callback
/showthread.php 1651 eval
as per title...
lines are a little out of shape after trying to use them on the 2.1....but all fine.
£30posted
should say these are turbo ones
bump to top
bumpy
£25 posted?!
bump for a bargain
  Hdi 90 Bosch R65 pump and injectors, bosch ecu and barrel key, clocks etc 85k Redordead89 7 5,797 10-10-2015, 05:17 AM
Last Post: Paul_13
  9mm bosch pump inc lines & injectors Matt-Rallye 7 4,876 05-10-2015, 11:16 AM
Last Post: Matt-Rallye
  9mm Bosch Pump with Lines & Injectors. Matt-Rallye 3 3,356 25-08-2015, 08:07 AM
