XUD Clutch In HDI?
XUD Clutch In HDI?
Basically as per title, will a xud clutch work in a hdi box? been offered a xud paddle?
Silver Five Door D-Tuurbo'! More Doors More Whores y0! Wink
It will work yes, you need to nick a few bits from an XUD gearbox to change it from a push to a pull type mechanism though
Would you be nice enough to give me a list of what i need?
Sorry mate, cannot remember off the top of my head I'm afraid, sure someone else will be along shortly though
Okay bud no problemo! would it be easier to just go xud box?
Depends what you're after really, if you did swap to a XUD box it would make it a bit revvier as the ratios are longer on a HDi gearbox..
& iirc that's just a straight swap no?
Hdi is push clutch, xud is pull...
You have to convert between the two, so you need a 2.0 petrol flywheel as they have the reluctor ring needed for a HDi but are pull style... You also need the fork out of any pull style clutch gearbox...
No, you'd need the flywheel from a GTi6 too iirc
EDIT: What he said ^^
Yep as ruan says you need
Flywheel off an XSi/GTi6
The fork and arm through the gearbox
DT Clutch cable
Cable bracket for the gearbox
New Flywheel bolts
Plus obviously the clutch and the release bearing.
Its an easy enough swap but you wont be able to lock the flywheel to do a cambelt change as the petrol flywheel dosent have the locking hole.
