How to remove throttle cable outer sleeve?
Evening all,
Have removed the throttle cable from inside the sleeve, now need to work out how to remove the sleeve from the car..
Any tips? Seems to be plugged at the firewall, and just above the top of the throttle pedal. Is it simply a case of yanking away?
Cheers.
Captain Standard
Took the white clip off the cable? the one that goes in the top of the pedal
  Throttle cable adjustment DM123 2 2,893 22-02-2016, 10:51 PM
Last Post: DM123
  Shorter throttle cable Nathan1305 7 4,689 24-03-2015, 09:02 AM
Last Post: Mattcheese31
  306 XUD throttle cable... toseland 1 2,189 08-08-2014, 07:14 PM
Last Post: Curt
