CORSA- indicator issue
Okay so I know I have a crappy Corsa, but I'm just wondering if anyone has any advice/knowledge of their electrics?
Recently, every time I indicate left and brake at the same time, the fog light sign on my dash flashes, and both my rear indicators come on. If I'm not braking however, it works fine.....
Is this a simple fix or a big thing? Got my MOT in April and I don't want to have to fork out loads as I'm looking at a new car....
Thanks!
[Image: kim.png]
Most likely to just be loose connections shorting out on each other (touching when they shouldnt touch). Its usually just a fault with the connector on one of the rear lights. If you pull the plug out of each of the back lights just check to see if anything looks dodgy, exposed wires or corrosion/dirty terminals on the plugs.
Simple. Buy a 306!
If you (or get Scott to do it!) take the rear lights out, check the boards in them and make sure there all intact and not corroded
That sounds pretty simple then! Cheers!
Niall I am looking, but can't buy anything for a couple of months as we're off to Canada in 3 weeks! So really I need her to pass the MOT so I can save up for a shiny shiny car.....
[Image: kim.png]
Canada? You've just bloody been! Lol
Burn it with fire and then claim on your insurance Big Grin
that way you don't have to fix the electrical problem* and get a new car!
*I hate car electrics & its probably best to ignore this advice totally!
Team Orange Engine Bay
Niall, Scott went but I didn't, so I'm due a trip! Lol
Mark....as tempting as that is I think I'll give it a miss....
[Image: kim.png]
Dodgy earth at the rear, clean up all the contacts
[Image: SDC10442-1.jpg]
NiallHarper Wrote:Simple. Buy a 306!
I think we all know this is NEVER the solution to an electrical problem...
Yeah, as said, sounds like a dodgy earth/connector Smile
will be corrosion, short or bad earth
Fire will definitely fix this issue. Or just clean the contacts if you insist on keeping a corsa on the public roads. Lol
[Image: c6769879.jpg] TEAM TRACK CAR + An E60 530d M-Sport for the daily
as already said it will be a bad earth, clean the contacts if its still shit, create your own earth, its to do with how your sending a live through the wire, and becouse it cant reach its own earth it trys to find another one, and that might mean running through other componants switching them on, till it creates a circuit.
I think this issue indicates you need a 306 of-corsa Big Grin
[Image: ocpic2.pg.jpg]
http://www.sanderson-brown.com
MrsMoonstone Wrote:Cats eyes get in the way of the racing line!
Moonstone HDi Phase 3- Scrapped Sad --- 1.6 Phase 2 - Scrapped Sad --- BMW 318is 1993 (Hyperventilates)
Haha, I knowwwww! I am looking but can't do anything for a couple of months as we're going away in 3 weeks. Just need to make sure she passes the MOT so I can keep saving for a shiny shiny pug!
[Image: kim.png]
Man up and get a 6 already!
Give me the money and I will!!! Having a 6 will be an extra £100 in tax, an extra £300 in insurance and more in fuel, so it's not easy.
Aside from the fact that all the decent ones seem to be ph2s or in a colour I don't like!
[Image: kim.png]
I'm honestly surprised no one has suggested the issue is purely that she has a Corsa.
ninja
Don't be hating on the Corsa you! Don't forget how you got from A to B when the S16 was broken.....
I say broken, I mean when Pug Performance decided they wanted to play with it :roll:
[Image: kim.png]
I've worked it out.
Vauxhalls have this system built in to self destruct after a certain time starting with the indicators failing. The purpose of this system is so that one owner doesn't become chronically ill from driving a Vauxhall for a long period of time.
Once it's started, the only way you can stop it is by
A) set fire to it
B) crash it into something substantially heavy
C) take it to the scrap yard
D) leave it running outside halfords for some chav to take it.
Unfortunately, this 'disease' follows you and not the car and therefore even if you go out and buy a brand new Vauxhall, within a matter of minutes you will have problems.
Only cure...buy a gti6!
KimmieKat Wrote:Don't be hating on the Corsa you! Don't forget how you got from A to B when the S16 was broken.....
oh you took yours to pug performance.... yeah i did aswell broke most bolts, bodged it all back together and left my drop links loose becouse they tryed doing it with an air gun and stripped the ball joint out and popped it, so i had to buy new ones about week after becouse i got a knock ever since they fitted it, also waited from about 9 till about 4 in the afternoon to drop a rear beam...
NiallHarper Wrote:I've worked it out.
A) set fire to it
:think: lmao
[Image: kim.png]
Kim itll be an earth thing. When we come over to fix scotts car at the weekend (and you make bacon sarnies) Ill have a bash at fixing it for you.
Dum-Dum Wrote:Kim itll be an earth thing. When we come over to fix scotts car at the weekend (and you make bacon sarnies) Ill have a bash at fixing it for you.
Hammer and fire doesn't solve everything you realise this Chris?
In this case though, it Definately will ninja
I'd best get the bacon in........
I don't want to kill her Niall!!
[Image: kim.png]
KimmieKat Wrote:I'd best get the bacon in........
Ok well we can look at it at the weekend when we fix Scott's broken car *awaits ban*.
Don't blame me if it accidentally catches fire though ninja
You'll be sorry if it does and your car goes missing also whistle
[Image: kim.png]
I'll come in the skoda then. Couldn't care less if the goes lol
Damn you! Tongue
[Image: kim.png]
[Image: 5b6.jpg]
Scott Wrote:
NiallHarper Wrote:Ok well we can look at it at the weekend when we fix Scott's broken car *awaits ban*.
[Image: 5b6.jpg]
Would I Scott? I do actually like the coupes. Still no 306 though when it comes to corners!
  Indicator Issue Kezzieboy 4 2,805 27-07-2014, 03:32 PM
Last Post: Kezzieboy
  Indicator / Hazzard Issue rocker8742 5 3,557 30-03-2014, 09:16 AM
Last Post: rocker8742
  Odd indicator issue Control_67 8 5,870 09-03-2014, 12:05 AM
Last Post: Control_67
