Another rear axle thread (camber)
Sorry about opening another rear axle thread.
Basically I have a bit of camber on the rear tyres, both sides. I've just had the car MOT'ed today, I had the guy have a look at the trailing arms as I tried moving them but he could not see any play. They're not making any noises, creaking, squeaking, they're not seized and move smoothly through their range of movement.
So my question is this, what is causing the camber on the rear wheel?
How much camber is there? There is a small amount as standard
Were the shocks ARB & TBs still in? If so take them out out and try the trailing arm again. You will prob find its like a flag in the wind
similar to my 205 - rear wheel had collapsed in, rubbing the arch, and was fooked. No movement at all, but when the beam was off the bearing had collapsed completely.
(27-06-2013, 11:39 AM)Grant Wrote: How much camber is there? There is a small amount as standard
Not much just a little.
[Image: IMG_20130424_132528_zps0d9eb0ab.jpg]
[Image: IMG_20130424_132512_zpsbade0842.jpg]
Not the best pics but you can see it leaning in a bit at the tops.
(27-06-2013, 11:47 AM)puglove Wrote: Were the shocks ARB & TBs still in? If so take them out out and try the trailing arm again. You will prob find its like a flag in the wind
No, I didn't have the bars out at the time.
(27-06-2013, 12:00 PM)ginge191 Wrote: similar to my 205 - rear wheel had collapsed in, rubbing the arch, and was fooked. No movement at all, but when the beam was off the bearing had collapsed completely.
Yeah that sounds like my girlfriends 206. That's clunking about at the moment.
Going by that 1st pic it looks to be quite bad IMO
But it is hard to tell from a pic
Disc beam? one here if so.
£60
Cheers Chris but I've got a spare. Going to refurb it and stick it on when I get chance. Need to do my girlfriends axle first.
  Rear stub axle sizes weka 2 4,091 26-04-2019, 06:18 PM
Last Post: weka
  rear axle joe67 4 5,140 25-04-2018, 08:38 PM
Last Post: carlukepeugeot
  rear axle beam tube quality dsm482 10 8,457 22-12-2017, 02:01 AM
Last Post: dsm482
