white smoke and rough idle
This is after a pump change so my guess is I need to adjust the pump on the bracket. Which way do I turn the pump or is it just trial and error?
TD04 11mm Sedan, now 2.1 vnt
Provence Dturbo Dead
Blaze 1.6 Dead
You mean advance it? Move it Towards the block I'm sure
Venetian XUD ph2 heaven
Ph3 perv cab heaven
Black ph1 XUD died
Moonstone hdi stage 2
There are two things to check: Timing and fuel filter. If the timing is correct then I would suggest changing the fuel filter, as a blocked fuel filter will interfere with injection timing. You adjust the pump away from the engine for later injection and towards the engine for earlier injection. About 3/4rds is the correct setting.
Is it revving up ok? Make sure its time up well, pull brave and tight over the pump pulley hold the tension onto and over the cam pulley then release the tentioner to hold it. Did you move the studs if its a lucas to bosch swap?
Never took belt off so it should be timed fine and fuel filters new. does rev fine when driving just start up
Blaze 1.6 Dead
  Xud9 White smoke and primer wont stay hard Donny165 5 5,658 13-07-2020, 12:22 AM
Last Post: ekjdm14
  rough idle very smoky blinkyeatu 3 2,862 03-07-2015, 03:01 PM
Last Post: blinkyeatu
  Rough start (misfiring) Dturbobooost 3 3,194 28-12-2014, 05:40 PM
Last Post: daddyfixit
