Good evening guys just got back from the test station with a big fat freddy. Just looking for some advice as to the best way going about repairs.
Failures
1. Offside track rod end ball joint has excessive play.
Shouldn't have a problem doing this one
2/3 nearside and offside headlamp aim too low.
Whats the best way of checking these are at the corrext level?
4. Parking break efficiency below requirements
8%
Thought this was a good level
5 off and nearside recorded little or no effort
Guys in the garage said this could be due to the break pads wearing thin which was an advisory. Changed the fronts the other week with no problems are the rear disks similar?
As for the other advisories both anti roll bar ball joints have play.
As I understand these are the drop links is that right?
Cv boot damaged but not letting in dirt.
Oil leak
Steering wheel rubber is loose
And finaly the undertray was not fitted securly.
The failures are my obvious important parts to sort, but there is also a rumble coming from the drivers side front wheel. I was hoping that something would be shown up in here that would give me an idea as to what was causing it. Its speed dependent and not affected by the revs so I had thought it was knackered bearings.
Is this likely to be cause by thr track rod or the anti roll bar? Or am I looking for another cause?
Thanks in advance
Failures
8%
Oil leak
Thanks in advance
![[Image: 2jcaw6b.jpg]](http://i43.tinypic.com/2jcaw6b.jpg)
