Threads: 58
Car Model/Spec: v70r
It's probably been asked before, but I've just bought some new GTi-6 front caliper and plan to stick them on my D Turbo! Main question is, do I need to change the master cylinder to a GTi-6 one or can I run them on a D Turbo one? Thanks!
personal prefference really.
I would. others wouldnt.
Threads: 127
33
Car Model/Spec: ZX Volcane TD
If you can be arsed to bleed the entire system from head to toe go for it. Might be a nice idea to refresh the brake fluid anyway.
Personally haven't had any issues running without, you'll get used to slightly longer pedal travel, its no biggie really.
Threads: 87
48
(09-06-2013, 01:03 PM)zx_volcane Wrote: If you can be arsed to bleed the entire system from head to toe go for it. Might be a nice idea to refresh the brake fluid anyway.
what he said^^^^^^^^^^^^^^^^^^ . .
Threads: 57
Car Model/Spec: 306 s16 406 v6 Saab 93 Ttid
Given 3 thank(s) in 3 post(s)
Ideal time to fit some braided lines aswell
Threads: 236
36
I'd definitely consider it, I ran standard MC and the pedal travel is shocking, doesn't inspire confidence. Unless you like to feel the brakes working once the pedal is nearly in the carpet...
Threads: 58
Another quick question, are these brakes the same as the Xsara VTS ones? Can anyone confirm this?
Threads: 48
Yeah, check the number stamped near the piston. Should be 57
Peugeot 206 GTI HDI
Volvo V50 2.0d
Volvo XC90 D5
