gti6 brake upgrade problem
hi guys went to upgrade my brakes on my 306 1.9d 2000 to the bigger gti6 brakes but came across a problem the caliper isnt lining up with the hub and the bolts arent going in its the lucas type gti6 brakes anybody else had this problem
Are you chaning the carriers? The bit the caliper bolts to.. which bolts to the hub?
yip have the full lot carrier and caliper
So is the carrier not lining up?
I know with mine had to use bolts from gti6
the holes dont line up but thats the thing
They should line up no problem, bolt holes on hub to gti6 caliper carrier
thats what a thought but nope am starting to think ive been ripped off with my 283mm discs the caliper still needs to come out another 40mm so going to try and get my money back
they put me in mind as if there off a 406 coupe 2.2
Post up a pic fella. With a tap messure aross the holes so we can see what they messure out at
there definitely off a 406 check with my mates 406 coupe and there the exact same and managed to get hold of calipers off a gti6 and there different but i now have the proper calipers and moneys been refunded lol
  Rear Brake Compensators - why do GTI6 have it but not any other 306s? MY95 5 3,492 08-10-2016, 06:22 PM
Last Post: Toms306
  brake problem MrBigMac 25 9,911 05-09-2015, 05:00 PM
Last Post: MrBigMac
  Rear brake upgrade? Ben 17 10,630 10-06-2013, 09:40 PM
Last Post: Anton
