11-02-2012, 06:01 PM
Whats the diffrence between the galletto 1260 or kwp2000 software remap or cables etc?
Which one the best or easyesy to use?
306 hdi
thanks
306 hdi
thanks
Which one the best or easyesy to use? 306 hdi thanks
12-02-2012, 10:47 AM
I've used the galletto and didnt have any trouble it was easy to use and it got the job done Hope that helps
18-02-2012, 06:26 PM
Both are easy to use and both are as good/reliable as each other for the 306 HDi...
I have a Galletto and KWP2000 and I use the KWP2000 almost all the time with 306 HDi's etc... just seems like less frills which to me says less likely to go wrong hehe Dave
03-03-2012, 11:02 PM
Im thinking of having a stage 1 remap sometime soon.
Which one uses windows 7 Galletto and KWP2000? Also which one uses xp? Can you save all the original ecu maps before doing any changes with new ones?
04-03-2012, 08:39 AM
i use a KWP on XP.
and yes you can save the original map which is recomended to do. bewarned though if you have a bad write with the kwp you wont be able to recover the ECU with the kwp but it is repairable by other chip programmer companys
06-03-2012, 03:56 PM
A bad write with anything on the EDC15 in the 306 HDi is an ECU out and solder job, I'm fairly certain... perhaps a byteshooter might work, I'm not sure.
I'd imagine both the Galletto and KWP2000 both have as much chance of going wrong, and that is mainly down to user error in almost all cases. A very good logic to follow is that if the device logs onto the car, and reads off a good original file, then the chances are it will write properly too (ie, you could consider that no hardware failures/faults are present if it reads ok) I'd always read and check the file is good, and also check what you have already, before doing any write. It assures the OBD connection is good, your laptop is good (drivers/stability), and the ecu interface device (kwp/galletto) is in good order and works! Dave
20-06-2012, 09:21 AM
Hey whippy. I'm going to be mapping my car over next few days. I was just wondering if there is any Gallettos to avoid on eBay as they're some at £20-25 and some at £10-15.
Also how much do you charge for a stage 1 map for my hdi?
20-06-2012, 09:42 AM
They are all the same, copies of copies with differing markups and software version rips (depending on age of batch - from what I have found anyway..)
It's hit and miss as to whether you get a working one - there are faulty ones about, dodgy batch no doubt. Dturbo GT2259s build thread; http://306oc.co.uk/forum/thread-3692.html Daily driver; 330d Msport (doesn't blow up!) |
FAO: Galletto/KWP2000/ELM327 Users | Ruan | 10 | 3,788 |
01-11-2014, 08:16 PM Last Post: Razorback_Rob |
Galletto 1260 won't read data | Hdi and proud of it | 7 | 2,798 |
21-10-2014, 09:48 PM Last Post: Hdi and proud of it |
Hdi mapping software/vnt ecu control | Chris306 | 14 | 3,789 |
06-09-2014, 03:05 PM Last Post: Ruan |
