07-06-2013, 06:03 AM
As titled my hdi cuts out when i try and go up through the gears turn it of for a few seconds, turn it bk on starts but engine management light is on?? Any ideas
Hdi cuts out when accelerating hard
http://306oc.co.uk/forum/thread-1497.html
Can guarantee that'll be a p0230 code, get testing. Good luck!
Fuel pressure sensor, that sounds like to me. Mine does it now and then, when I put my foot down.
07-06-2013, 01:37 PM
Probably not an frps issue Tom, usually wiring, injectors or hp pump in my experience. I can chuck it on pp2k next time you're about if you like, get a better idea of what the problem is.
07-06-2013, 03:10 PM
07-06-2013, 03:17 PM
I've seen it before, on stage 2 only.. when having less than a quarter of a tank under brutal acceleration the torque would throw the fuel to the back of the tank and cause it to starve/cut out.. At least it's cheap to check haha
07-06-2013, 03:50 PM
(07-06-2013, 01:37 PM)Poodle Wrote: Probably not an frps issue Tom, usually wiring, injectors or hp pump in my experience. I can chuck it on pp2k next time you're about if you like, get a better idea of what the problem is. Iv got pp mate, and mine has popped up with that and my mate had the same problem but his wouldn't come out of limp mode then cut out about half a mile up the road, so changed that sensor problem sorted. Probs coming slightly off the subject there lol
Fair enough, well i've got a couple of spare sensors kicking about the place if you'd like to try them? Plus a ton of other bits we can swap about to help find the issue.
| HDi Cuts Out | RPug | 3 | 4,755 |
01-10-2019, 01:49 PM Last Post: WandaGray |
| Cuts out at 2000rpm | Dicky | 3 | 3,467 |
23-10-2014, 09:48 PM Last Post: Dicky |
| Cuts out when driving | Frosty | 19 | 10,148 |
27-12-2013, 10:07 AM Last Post: Poodle |
