driveshaft or ball joint?
Right guys just took my coilies out and put in springs but now have a loud clonking from the drivers side when turning right or when I hit a dip in the road on the right wheel.
The is driveshaft boot was loosing grease so we repacked it but still there. Going to sort it today but need an indication that it would be either one of those two?
[Image: 20gh7o0.jpg]
Sounds like top mount bearing to me
Team Doesn't own a 306
Way to test? I thought driveshaft because of the amount of grease it lost but not sure
Get someone to turn the steering lock to lock while you look at the top mount under the bonnet see if you can hear it clunk, a driveshaft will usually click while goin round a corner not really lock to lock
Well when going around a roundabout it does clonk repeatedly. I will check the top mounts
Okay so just went to a car park and drove on circles full cut to the right and no clonk. Seems to be mainly when the right wheel goes up/down. still happens when turning right around a corner though, nothing when turning left
check the topmount 6mm fixing bolts for length they might be catching the spring on turning
  Ball joint/ Hub to strut pinch bolts Uberderv 7 5,548 04-01-2018, 11:40 AM
Last Post: Mighty306
  fitting a front suspension ball joint impotentials 3 3,844 29-10-2016, 05:46 PM
  Bottom ball joint sizes Xsikid 4 3,688 04-05-2016, 05:45 AM
Last Post: Paul_13
